[GRASS-dev] Re: [GRASS GIS] #930: Wingrass7 - compiling errors
trac at osgeo.org
Sun Feb 14 12:58:23 EST 2010
Reporter: hellik | Owner: grass-dev at lists.osgeo.org
Type: defect | Status: new
Priority: normal | Milestone: 7.0.0
Component: Compiling | Version: svn-trunk
Resolution: | Keywords: wingrass, grass7
Platform: MSWindows Vista | Cpu: Unspecified
Comment (by glynn):
Replying to [comment:2 hamish]:
> > The MinGW headers don't have any equivalent of _FILE_OFFSET_BITS.
> > There is a 64-bit off_t and 64-bit versions of stat(), lseek(),
> > etc, but there's no option to redirect the standard names to their
> > 64-bit equivalents; we would need to do that ourselves.
> is this something which should be in the MinGW wish tracker, or is it
just for us?
I suspect that there would be reasons why they haven't done something like
this.
E.g. I note that there are two different candidates for the 64-bit version
of the stat structure and function, depending upon which version of MSVCRT
is being used.
Ticket URL: <https://trac.osgeo.org/grass/ticket/930#comment:3>
