[GRASS-dev] Re: [GRASS GIS] #96: v.surf.bspline column option broken
GRASS GIS trac at osgeo.org
Sun Feb 14 13:30:41 EST 2010
  Reporter:  cmbarton  |       Owner:  grass-dev at lists.osgeo.org
      Type:  defect    |      Status:  reopened
  Priority:  major     |   Milestone:  6.4.0
 Component:  Raster    |     Version:  unspecified
Resolution:            |    Keywords:  v.surf.bspline
  Platform:  All       |         Cpu:  All
Comment (by cmbarton):
 Following Helena's suggestion, I did a make distclean BEFORE running svn
 up. Still same result. Cannot use 3D points and 2D points with attribute
 don't work.
 So v.surf.bspline has gone for me from working under constrained
 conditions to not working at all.
 BTW, using the layer=-1 for 3D points is poor interface design. There
 should be a flag for this. It should not depend on using an illegal value
 for layers.
 A couple new results that I'll report elsewhere. The GUI no longer
 launches automatically and the r.bilinear is greyed out.
Ticket URL: <http://trac.osgeo.org/grass/ticket/96#comment:17>
