[GRASS-dev] Re: [GRASS GIS] #929: g.transform: dump coeffs and
transform sparse points
trac at osgeo.org
Sun Feb 14 13:38:25 EST 2010
#929: g.transform: dump coeffs and transform sparse points
Reporter: hamish | Owner: grass-dev at lists.osgeo.org
Type: enhancement | Status: closed
Priority: normal | Milestone: 7.0.0
Component: Imagery | Version: svn-trunk
Resolution: fixed | Keywords: g.transform
Platform: All | Cpu: All
Comment (by glynn):
Replying to [comment:4 hamish]:
> I am wondering if this is useful for us but I am reminded that in stats
that the simplest model fit that explains the data is usually the best one
to use. You can use high nth-order polynomials to exactly fit the data,
but what you are really doing is fitting the noise.
I would expect that you're typically trying to find a suitable
approximation to a complex analytic function (i.e. a typical cartographic
or geometric projection).
For many projections, a quadratic polynomial will be a poor fit. The main
reason for using cubic functions for interpolation is that you can specify
both the value and first derivative at each end (4 degrees of freedom).
If you consider approximating sin(x) symmetrically about zero: you can get
a reasonable approximation with a cubic function, but the optimal
quadratic approximation will actually be linear.
Note that the most complex case in the above code is the same as
g.transform with order=3, i.e. generalised cubic (rather than bicubic).
Ticket URL: <https://trac.osgeo.org/grass/ticket/929#comment:5>
