[GRASS-dev] No GUI startup in GRASS 7
Michael Barton Michael.Barton at asu.edu
Mon Feb 15 01:45:52 EST 2010
Nope neither one. Good idea, but it is something else.
I think what may have happened is due to recent work to make GRASS work with Windows because I can no longer run python scripts from a folder in a path with spaces and GRASS_ADDON_PATH no longer recognizes spaces.
Take a look below...
GRASS 7.0.svn (Spearfish60_test):~ > $GRASS_ADDON_PATH
bash: /Users/cmbarton/Desktop:/Users/cmbarton/Library/Application: No such file or directory
This has no trouble with the GRASS_ADDON_PATH I set in .profile (no spaces), but truncates the GRASS_ADDON_PATH set up in the Mac startup script (/Users/cmbarton/Library/Application Support/GRASS/modules/bin  with spaces)
I'm changing the name of this and filing a bug report.
Michael
On Feb 14, 2010, at 9:28 PM, William Kyngesburye wrote:
> This mysterious problem showed up a while back (6.3?) then went away (6.4?).  Mysterious then.
> For this time around, how about:
> http://trac.osgeo.org/grass/changeset/40985
> On Feb 14, 2010, at 9:56 PM, Michael Barton wrote:
>> William
>> Do you have any clue why GRASS 7 would stop launching the GUI when opened? This change happened sometime between 11 and 14 February, and more likely in the last couple days.
>> Michael
> William Kyngesburye <kyngchaos*at*kyngchaos*dot*com>
> http://www.kyngchaos.com/
> "I ache, therefore I am.  Or in my case - I am, therefore I ache."
> - Marvin
