[GRASS-dev] [GRASS GIS] #943: wxpython gui hangs after switching to
cairo display driver
trac at osgeo.org
Mon Feb 15 12:08:59 EST 2010
#943: wxpython gui hangs after switching to cairo display driver
Reporter: epatton | Owner: grass-dev at lists.osgeo.org
Type: defect | Status: new
Priority: normal | Milestone: 6.5.0
Component: Display | Version: svn-develbranch6
Keywords: cairo, driver, gui, wxpython | Platform: Linux
Cpu: x86-64 |
The wxpython Map Display window freezes and becomes unresponsive after
changing the display driver from 'default' to 'cairo'.
I have compiled Grass 6.5 from a fresh checkout from svn, set --with-
cairo, --with-cairo-libs=/usr/lib, and --with-cairo-includes=/usr/include.
One thing I just noticed is that the configure line
checking for cairo linking flags...
appears as it does above, with no confirmation about whether or not it
found cairo linking flags. But then I'm not sure it it's supposed to print
anything in a successful case, either.
I've checked my package manager, and I have libcairo2 and libcairo2-dev
installed, versions 1.8.8.
Anything else I should check? Can anyone confirm this error?
Thanks,
~ Eric.
Ticket URL: <http://trac.osgeo.org/grass/ticket/943>
