[GRASS-dev] Re: [GRASS GIS] #922: GRASS installer can not install unser "program files" (Windows7 only)
GRASS GIS trac at osgeo.org
Mon Feb 15 14:28:11 EST 2010
  Reporter:  naokiueda     |       Owner:  grass-dev at lists.osgeo.org
      Type:  defect        |      Status:  new
  Priority:  major         |   Milestone:  6.4.0
 Component:  Installation  |     Version:  svn-releasebranch64
Resolution:                |    Keywords:  wingrass, WIndows7
  Platform:  MSWindows 7   |         Cpu:  Unspecified
Comment (by hellik):
 Replying to [comment:13 cristn]:
 > Replying to [comment:10 hellik]:
 > > Replying to [comment:9 cristn]:
 > > > Replying to [comment:7 hellik]:
 > > > > Replying to [comment:6 hellik]:
 > > > > could this a issue with the UAC in Win7.
 > > > Apparently yes: as for the original reporter, always "Skipped"
 appears. So the locale is not the issue but the problem that I cannot
 write in "c:\Program Files".
 > > > When installing instead in C:\user\somebody\Documents\GRASS-64-SVN\
 it works ok. So "c:\Program Files" seems to be protected.
 > > is the installer working (means installing in c:\Program Files) for
 you with mouse right click and "run as administrator"?
 > It works like this and no longer skips files when installing.
 > Great (but not obvious...)
 > Cris
 so can we close the ticket?
 Helmut
Ticket URL: <http://trac.osgeo.org/grass/ticket/922#comment:14>
