[GRASS-dev] Re: [GRASS GIS] #943: wxpython gui hangs after
switching to cairo display driver
trac at osgeo.org
Tue Feb 16 00:36:04 EST 2010
#943: wxpython gui hangs after switching to cairo display driver
Reporter: epatton | Owner: grass-dev at lists.osgeo.org
Type: defect | Status: new
Priority: normal | Milestone: 6.5.0
Component: Display | Version: svn-develbranch6
Resolution: | Keywords: cairo, driver, gui, wxpython
Platform: Linux | Cpu: x86-64
Comment (by glynn):
Replying to [ticket:943 epatton]:
> I have compiled Grass 6.5 from a fresh checkout from svn, set --with-
cairo, --with-cairo-libs=/usr/lib, and --with-cairo-includes=/usr/include.
You should never need to specify /usr/lib or /usr/include explicitly
(however, recent versions of GCC will explicitly ignore them, so it's
harmless).
On Linux, you should only need --with-cairo, which obtains the compiling
and linking flags via pkg-config. The --with-cairo-includes, --with-cairo-
libs, and --with-cairo-ldflags switches are there for platforms lacking
pkg-config.
> One thing I just noticed is that the configure line
checking for cairo linking flags...
> appears as it does above, with no confirmation about whether or not it
found cairo linking flags. But then I'm not sure it it's supposed to print
anything in a successful case, either.
It prints whatever you specified for --with-cairo-ldflags. If you didn't
use it, then it won't print anything.
If the cairo driver gets built, there's nothing wrong with the configure
switches. If it doesn't work, that suggests a bug in either the driver or
the GUI.
Ticket URL: <http://trac.osgeo.org/grass/ticket/943#comment:4>
