[GRASS-dev] Re: GRASS 7 status overview
Hamish
hamish_b at yahoo.com
Tue Feb 16 02:37:31 EST 2010
Hamish:
> > With continual refresh I worry that ximgview and wximgview will not
> > be much use ssh'ed from the near-dialup connection speeds from home.
> You can use percent=0, in which case it will only update
> when it receives SIGUSR1 (that doesn't work on Windows;
> suggestions?).
> You can use e.g.
> GRASS_NOTIFY="killall -USR1 `pidof wximgview`"
> to cause SIGUSR1 to be sent whenever a module calls
> D_close_driver().
then I get:
G7> d.erase
7682: no process killed
but no refresh.
resizing the window slightly by dragging its window manager frame's
corner a little redraws it.
> OTOH, if the issue is X bandwidth rather than application CPU usage,
> it would be possible to add an option to only perform a redraw if the
> data changes.
wximgview @ percent=100%, top shows:
sshd 20%
wximgview: 11%
the numbers fluctuate a little, but the ratio stays about the same.
(100mbit ssh -X)
> BTW, there is also the wxpyimgview script, which is the same thing but
> written in Python rather than C++. It didn't occur to me to use Python
> until shortly after I'd finished writing wximgview. The original
> reason for using C++ was that I assumed that I would have
> to perform the RGBA->RGB conversion in Python, which would be
> insanely slow; then I realised that I could use NumPy.
@ 100% top shows:
sshd: 16%
python: 15%
...and
ximgview @ 100% top shows:
sshd: 14%
python: 12%
Hamish
