[GRASS-dev] Trac: Edit a single wiki section plugin
Hamish
hamish_b at yahoo.com
Tue Feb 16 21:14:17 EST 2010
Martin:
> > big yes! AFAIK this plugin requires version 0.11,
> > unfortunately OSGeo Trac instaces runs on 0.10.3.1 See [1].
Markus:
> OSGeo is in the process of acquiring two big servers which
> will be hosted in a different place than the current one.
> Then services like trac etc will be moved and updated.
fyi,
in Debian/stable the version is: 0.11.1-2.1
and from backports.org: 0.11.6-1~bpo50+1
so the new servers should be able to handle it.
my advc. is to stick with the stable versions unless you just
can't live without something. (as better security fixes, support
etc using the official version)
Hamish
