[GRASS-dev] [GRASS GIS] #950: Error opening workspace file
GRASS GIS trac at osgeo.org
Wed Feb 17 09:33:18 EST 2010
 Reporter:  epatton         |       Owner:  grass-dev at lists.osgeo.org
     Type:  defect          |      Status:  new
 Priority:  normal          |   Milestone:  6.5.0
Component:  wxGUI           |     Version:  svn-develbranch6
 Keywords:  gui, workspace  |    Platform:  Linux
      Cpu:  x86-64          |
 I get the following error after trying to open a workspace file in Grass
 6.5.svn:
   File "/usr/local/grass-6.5.svn/etc/wxpython/wxgui.py",
 line 622, in OnWorkspaceOpen
 self.LoadWorkspaceFile(filename)
 line 717, in LoadWorkspaceFile
 lvdigit=layer['vdigit'])
 KeyError
 'vdigit'
 This error only seems to manifest itself when layer group folders are
 used.
 To replicate error (in North Carolina dataset, Grass 6.5.svn):
 1. start wxpthon gui, add vectors streams, lakes, geodetic_pts. Add raster
 elevation.
 2. Save the workspace.
 3. Exit Grass, start Grass, load workspace, everything works ok.
 4. add layer group folder, drag vectors into folder. Save workspace and
 exit Grass.
 5. Start Grass, load workspace; wxgui gives the same error as above.
 ~ Eric.
Ticket URL: <http://trac.osgeo.org/grass/ticket/950>
