[GRASS-dev] Re: [GRASS GIS] #96: v.surf.bspline column option broken
trac at osgeo.org
Wed Feb 17 11:23:35 EST 2010
Reporter: cmbarton | Owner: grass-dev at lists.osgeo.org
Type: defect | Status: reopened
Priority: major | Milestone: 7.0.0
Component: Raster | Version: svn-releasebranch64
Resolution: | Keywords: v.surf.bspline
Platform: All | Cpu: All
Comment (by mmetz):
Replying to [comment:17 cmbarton]:
> So v.surf.bspline has gone for me from working under constrained
conditions to not working at all.
Please post the exact commands you used. BTW, when using 3D vector points,
just don't specify the layer option (it's optional anyway).
There are two vectors in the nc_spm_08 dataset that are suitable for
testing the column and 3D points mode:
precip_30ynormals at PERMANENT
and
precip_30ynormals_3d at PERMANENT
A good spline step value for these vectors is 50000 (the default is meant
for LiDAR points with 1m spacing).
Ticket URL: <https://trac.osgeo.org/grass/ticket/96#comment:22>
