[GRASS-dev] Access multiple files in a Python script file
Wed Feb 17 14:12:09 EST 2010
Luis Lisboa wrote:
> I'm working on 6.4.0 version and I want to build a Python scripts that acess
> multiple files. From GRASS7 i.spectral I see that raster variable is a
> multiple and this is performed.
> raster = options['raster']
> rastermaps = raster.split(',')
> My question is regarding this: how can I access second file for, for
> instance, do a mapcalc or a for cycle?
The .split() method returns a list, so in the above case you can use
e.g.:
	for map in rastermaps:
