[GRASS-dev] Re: [GRASS GIS] #955: v.digit background errors
trac at osgeo.org
Fri Feb 19 05:31:35 EST 2010
Reporter: clerici | Owner: grass-dev at lists.osgeo.org
Type: defect | Status: closed
Priority: normal | Milestone: 6.4.0
Component: Vector | Version: 6.4.0 RCs
Resolution: wontfix | Keywords: vector, digitizing
Platform: All | Cpu: All
Comment (by hamish):
Replying to [comment:2 clerici]:
> What's strange is that the procedure runs well on GRASS6.2.
IIRC Glynn rewrote it after 6.2, underneath the UI it's a different module
by the same name.
FWIW I had used the same background image trick in 6.2, but I seem to
recall it would crash after digitizing about 100 points or so. So I would
exit and restart often but still got caught every now and then when the
file was resized on the disk to accomodate the new points.
Hamish
Ticket URL: <https://trac.osgeo.org/grass/ticket/955#comment:3>
