[GRASS-dev] Re: [GRASS GIS] #659: probable memory leak in
v.surf.bspline
Markus Metz
markus.metz.giswork at googlemail.com
Fri Feb 19 11:22:14 EST 2010
GRASS GIS wrote:
> #659: probable memory leak in v.surf.bspline
> Reporter: hamish | Owner: grass-dev at lists.osgeo.org
> Type: defect | Status: closed
> Priority: normal | Milestone: 6.4.0
> Component: Vector | Version: 6.4.0 RCs
> Resolution: fixed | Keywords: v.surf.bspline
> Platform: All | Cpu: All
> Changes (by mmetz):
> * status: new => closed
> * resolution: => fixed
> Comment:
> Right, raster_matrix was allocated twice for some obscure reason. Fixed in
> all branches with the recent overhaul of the lidar tools.
BTW, fixed are also all the other memory leaks in some other lidar tools
when accessing the auxiliary table (db_free_string() was missing).
