[GRASS-dev] [GRASS GIS] #957: v.voronoi has extra lines in output
trac at osgeo.org
Fri Feb 19 21:01:03 EST 2010
Reporter: helena | Owner: grass-dev at lists.osgeo.org
Type: defect | Status: new
Priority: normal | Milestone: 6.4.1
Component: Vector | Version: 6.4.0 RCs
Keywords: | Platform: All
Cpu: All |
at least since 6.3 v.voronoi produces extra lines in the polygon output,
this example run with elev_lid792_randpts
has just one, but I have seen worse results:[[BR]]
http://skagit.meas.ncsu.edu/~helena/grasswork/voronoibug_poly.png
When converted to raster using v.to.rast, the result has holes (nulls),
indicating that some polygons do not have values assigned[[BR]]
http://skagit.meas.ncsu.edu/~helena/grasswork/voronoibug_rast.png
[[BR]]
These examples were done with grass65, but I get the same from 64[[BR]]
Helena
Ticket URL: <http://trac.osgeo.org/grass/ticket/957>
