[GRASS-dev] Re: [GRASS GIS] #128: NVIZ fails to load vector points
without other map
trac at osgeo.org
Sun Feb 21 07:00:26 EST 2010
#128: NVIZ fails to load vector points without other map
Reporter: neteler | Owner: grass-dev at lists.osgeo.org
Type: defect | Status: reopened
Priority: major | Milestone: 6.4.0
Component: NVIZ | Version: svn-trunk
Resolution: | Keywords: nviz
Platform: Unspecified | Cpu: Unspecified
Comment (by marisn):
Replying to [comment:16 hamish]:
> if (exag < 0.1)
> exag = 1.0;
You are right. It needs to be changed to GRASS_EPSILON test, as previous
code read (exag == 0.0) which isn't the best idea for float comparison.
Still IMHO some code might break if exag is 0 or less.
> ps- it is much easier to review if cosmetic (whitespace) changes are
kept to separate patches from bugfixes. signal to noise ratios and all
that. thanks
I allways run grass_indent.sh after codding FTW. I will prepeare new
patches with ignored whitespace changes (thouse where prepeared in 3 AM).
Ticket URL: <https://trac.osgeo.org/grass/ticket/128#comment:17>
