[GRASS-dev] Re: [GRASS GIS] #958: v.krige does not run in GRASS 7
Michael Barton
michael.barton at asu.edu
Sun Feb 21 23:06:53 EST 2010
Thanks Massimo,
I'll try this and keep working on it when I have a bit of time.
Michael
____________________
C. Michael Barton
Director, Center for Social Dynamics & Complexity
Professor of Anthropology, School of Human Evolution & Social Change
Arizona State University
voice: 480-965-6262 (SHESC), 480-727-9746 (CSDC)
fax: 480-965-7671 SHESC), 480-727-0709 (CSDC)
www: www.public.asu.edu/~cmbarton, http://csdc.asu.edu
On Feb 21, 2010, at 4:08 AM, grass-dev-request at lists.osgeo.org wrote:
> Date: Sun, 21 Feb 2010 10:30:44 +0100
> From: Massimo Di Stefano <massimodisasha at gmail.com>
> Subject: Re: [GRASS-dev] Re: [GRASS GIS] #958: v.krige does not run in
> GRASS 7
> To: grass-dev at lists.osgeo.org
> Message-ID: <6124F8DC-1467-4080-B89E-D6D1A70A72ED at gmail.com>
> Content-Type: text/plain; charset=us-ascii
> Hi Cameron,
> To install rgdal on mac osx i need to install rgdal manually from the terminal instead of use the gui,
> beacouse the gui method fails to find gdal and proy libs and include.
> when tring to install from the gui, scorll the "log" and look for the web address for rgdal
> (see also a section in the log where it suggest to install rgdal manually
> adding the " --configure-option " string)
> then :
> wget ...rgdal.tgz
> and insyall it manually from a shell using :
> R CMD install /path/to/rgdal.tgz --configure-options="add here the path to proy and gdal"
> i hope this can help.
> note.
> William has a binary packages for rdal
> you cn also give a it a try.
