[GRASS-dev] [r41158-60] d.vect: default line width to '1'
Martin Landa landa.martin at gmail.com
Tue Feb 23 14:03:53 EST 2010
2010/2/22 Glynn Clements <glynn at gclements.plus.com>:
>> anyway from user POV width=0 seems quite strange I guess.
> XDRIVER passes the line width directly to XChangeGC. X specifies the
> precise behaviour for non-zero line width, but drivers have some
> freedom as to how zero-width lines are handled, so they can use the
> hardware's "thin line" drawing primitive, if it has one. A width of
> zero can potentially result in significantly faster operation.
OK, so should I revert the changes?
Martin
Martin Landa <landa.martin gmail.com> * http://gama.fsv.cvut.cz/~landa
