[GRASS-dev] Re: [GRASS GIS] #960: Some hotkeys disabled in 6.5 wxgui
GRASS GIS trac at osgeo.org
Wed Feb 24 10:23:15 EST 2010
  Reporter:  epatton  |       Owner:  grass-dev at lists.osgeo.org
      Type:  defect   |      Status:  new
  Priority:  minor    |   Milestone:  6.5.0
 Component:  wxGUI    |     Version:  svn-develbranch6
Resolution:           |    Keywords:  hotkeys, wxgui
  Platform:  Linux    |         Cpu:  x86-64
Changes (by cmbarton):
  * summary:  Seom hotkeys disabled in 6.5 wxgui => Some hotkeys disabled
              in 6.5 wxgui
Comment:
 The GRASS shutdown, with Cmd/Ctl-Q or from the menus, doesn't work for me
 in GRASS 7 either. It's a good idea, but needs some work still.
 Ctrl/Cmd-V is used for the Paste function on all platforms and should not
 be mapped to a special function in GRASS. Same thing goes for Ctrl/Cmd-C
 (copy), Ctrl/Cmd-X (cut), Ctrl/Cmd-W (close window), Ctrl/Cmd-A (select
 all), and Ctrl/Cmd-Z (undo). Additionally, Ctrl/Cmd-P is commonly used for
 print, Ctrl/Cmd-F for find, Ctrl/Cmd-G find again, and Ctrl/Cmd-O for
 open. It would be wise to avoid these common hot key mappings too.
 Michael
Ticket URL: <http://trac.osgeo.org/grass/ticket/960#comment:1>
