[GRASS-dev] Re: [GRASS GIS] #889: Msys-based commands fail when
winGRASS is installed in %ProgramFiles%
trac at osgeo.org
Wed Feb 24 13:38:36 EST 2010
#889: Msys-based commands fail when winGRASS is installed in %ProgramFiles%
Reporter: lponti | Owner: grass-dev at lists.osgeo.org
Type: defect | Status: closed
Priority: normal | Milestone: 6.4.0
Component: default | Version: 6.4.0 RCs
Resolution: fixed | Keywords: wingrass
Platform: MSWindows Vista | Cpu: x86-32
Changes (by lponti):
* status: new => closed
* resolution: => fixed
Comment:
Replying to [comment:2 hamish]:
> hi, could you try the latest nightly wingrass build? I think this is now
fixed.
Hi, I tried r.shaded.relief with WinGRASS-6.4.SVN-r41137 and it works
perfectly fine.[[BR]]
I changed the ticket to fixed: is this OK?[[BR]]
Thanks,[[BR]]
Luigi
> Hamish
Ticket URL: <https://trac.osgeo.org/grass/ticket/889#comment:3>
