[GRASS-dev] Use Global variables at Scripts (Python)
Glynn Clements
glynn at gclements.plus.com
Thu Feb 25 16:15:58 EST 2010
Luis Lisboa wrote:
> I'm programming a few Scripts and I would like to know How can I access some
> global variables value such as GRASS_DIR, MAPSET; LOCATIOn or even others
> that I defined (e.g. GRASS_TEMP). How can I load and access them? (I'm
> working with Python scripts for GRASS 7)
Environment variables can be accessed using e.g.:
gisbase = os.environ["GISBASE"]
or:
gisbase = os.getenv("GISBASE")
The main difference between the two is that the former raises an
exception if the variable doesn't exist while the latter returns None
(or a user-defined value specified by the second argument).
$GISRC variables (GISDBASE, LOCATION_NAME, MAPSET) can be accessed via
grass.script.gisenv(), e.g.
import grass.script as grass
env = grass.gisenv()
mapset = env["MAPSET"]
