[GRASS-dev] Re: [GRASS GIS] #945: wxGUI: g.setproj fails on wingrass
trac at osgeo.org
Sat Feb 27 15:22:44 EST 2010
Reporter: hamish | Owner: martinl
Type: defect | Status: assigned
Priority: major | Milestone: 6.4.0
Component: wxGUI | Version: svn-releasebranch64
Resolution: | Keywords: g.setproj, wingrass
Platform: MSWindows XP | Cpu: x86-32
Comment (by glynn):
Replying to [comment:7 hamish]:
> another is that OnXTerm should unset the GRASS_MESSAGE_FORMAT enviro var
to avoid printing GRASS_INFO_WARNING(), GRASS_INFO_END() etc. to the
terminal.
# unset
del os.environ['GRASS_MESSAGE_FORMAT']
# reset
os.environ['GRASS_MESSAGE_FORMAT'] = 'gui'
Apart from at startup, the wxGUI should just leave os.environ alone. If a
child process needs a modified environment, pass it one via the env=
parameter to subprocess.Popen(), e.g.:
tmpenv = os.environ.copy()
tmpenv['GRASS_MESSAGE_FORMAT'] = 'gui'
p = grass.Popen(..., env = tmpenv)
If gcmd.Command doesn't support env=, it needs to be fixed.
Ticket URL: <https://trac.osgeo.org/grass/ticket/945#comment:8>
