[GRASS-dev] swig python compilation error in utils_wrap.c
Glynn Clements
glynn at gclements.plus.com
Sat Feb 27 16:07:35 EST 2010
Markus Neteler wrote:
> Since I am a bit lost here, I have posted the full swig compile sequence
> excerpt here:
> http://osgeo.pastebin.com/JxVbCwMz
> utils_wrap.c is compiled as well as the others. Perhaps you could take
> another look?
That only shows the linking of utils.so; the others have already been
built so there is nothing to compare it to.
You need to run "make clean" on that directory first.
