[GRASS-dev] win7 problem with new default installation path
Helena Mitasova
hmitaso at unity.ncsu.edu
Sat Feb 27 16:38:50 EST 2010
it still crashes when adding vector, but I don't see anybody else complaining
about this (as I said there is no problem when winGRASS is installed
under the previous path that did not have spaces).
I am not sure whether this should delay RC6
Helena
>>I removed the parentheses from the default installation path to:
C:\Program Files x86\GRASS-64-SVN
it was
C:\Program Files (x86)\GRASS-64-SVN
before.
It crashed. It is not the parentheses - the spaces cause the problem.
On Feb 26, 2010, at 4:01 PM, Glynn Clements wrote:
> Helena Mitasova wrote:
>> I tested the latest - they still crash when installed in the default
>> installation folder (C:\Program Files (x86)\GRASS-64-SVN)
> The folder is actually called "Program Files (x86)"? It's within the
> realms of possibility that something doesn't like parentheses in
> filenames.
> Glynn Clements <glynn at gclements.plus.com>
