[GRASS-dev] Re: [GRASS GIS] #111: r.los fails with high values for
max_dis parameter
trac at osgeo.org
Fri Jan 1 04:55:53 EST 2010
#111: r.los fails with high values for max_dis parameter
Reporter: gsancho | Owner: grass-dev at lists.osgeo.org
Type: defect | Status: new
Priority: major | Milestone: 6.4.0
Component: Raster | Version: svn-develbranch6
Resolution: | Keywords: wingrass r.los
Platform: MSWindows XP | Cpu: x86-32
Comment (by pcav):
Here it is (available for a while):
http://int.faunalia.it/~paolo/Toscana_rlos.tar.gz
Tested again with the command
r.los input=dtm at PERMANENT coordinate=1676734,4831167 obs_elev=100
max_dist=10000 output=rlos
and it fails
Ticket URL: <https://trac.osgeo.org/grass/ticket/111#comment:32>
