[GRASS-dev] Re: [GRASS GIS] #111: r.los fails with high values for max_dis parameter
GRASS GIS trac at osgeo.org
Fri Jan 1 07:36:32 EST 2010
  Reporter:  gsancho       |       Owner:  grass-dev at lists.osgeo.org
      Type:  defect        |      Status:  new
  Priority:  major         |   Milestone:  6.4.0
 Component:  Raster        |     Version:  svn-develbranch6
Resolution:                |    Keywords:  wingrass r.los
  Platform:  MSWindows XP  |         Cpu:  x86-32
Comment (by hamish):
 Replying to [comment:32 pcav]:
 > http://int.faunalia.it/~paolo/Toscana_rlos.tar.gz
 > Tested again with the command
 > r.los input=dtm at PERMANENT coordinate=1676734,4831167 obs_elev=100
 max_dist=10000 output=rlos
 > and it fails
 works for me on debian-etch-pentium4, (& it looks nice too!)
   http://bambi.otago.ac.nz/hamish/grass/bugs/rlos_onearth.jpg
 but I do see the segfault on debian-lenny-amd64 & GRASS 6.5svn.
 gdb session:
 G65> gdb `which r.los`
 (gdb) run input=dtm at PERMANENT coordinate=1676734,4831167 obs_elev=100
 max_dist=10000 output=rlos_test
 [Thread debugging using libthread_db enabled]
 warning: Lowest section in /usr/lib/libicudata.so.38 is .hash at
 0000000000000120
 Using maximum distance from the viewing point (meters): 10000.000000
 [New Thread 0x7fde555ce710 (LWP 31319)]
 Program received signal SIGSEGV, Segmentation fault.
 [Switching to Thread 0x7fde555ce710 (LWP 31319)]
 0x00007fde53ae9ee5 in memcpy () from /lib/libc.so.6
 (gdb) bt
 #0  0x00007fde53ae9ee5 in memcpy () from /lib/libc.so.6
 #1  0x00007fde552eb288 in segment_get (SEG=0x7fff7c5cf320,
 buf=0x7fff7c5cdd2c, row=-1,
     col=1054) at get.c:49
 #2  0x0000000000403b3e in find_inclination (x=0, y=150, viewpt_elev=249,
     seg_in_p=0x7fff7c5cf320, row_viewpt=149, col_viewpt=1054, docurv=0,
     ellps_a=6.9532466931849492e-310) at pts_elim.c:300
 #3  0x000000000040361f in hidden_point_elimination (head=0x16a2340,
 viewpt_elev=249,
     seg_in_p=0x7fff7c5cf320, seg_out_p=0x7fff7c5cf2e0,
 seg_patt_p=0x7fff7c5cf2a0,
     quadrant=1, sign_on_y=1, sign_on_x=1, row_viewpt=149, col_viewpt=1054,
 patt_flag=0,
     docurv=0, ellps_a=6.9532466931849492e-310) at pts_elim.c:94
 #4  0x0000000000403de7 in segment (segment_no=4, xmax=149, ymax=506,
 slope_1=0,
     slope_2=0.5, flip=1, sign_on_y=1, sign_on_x=1, viewpt_elev=249,
     row_viewpt=149, col_viewpt=1054, patt_flag=0, docurv=0,
     ellps_a=6.9532466931849492e-310) at segment.c:81
 #5  0x0000000000402dc0 in main (argc=6, argv=0x7fff7c5cf778) at main.c:328
 (gdb) frame 1
 49          memcpy(buf, &SEG->scb[i].buf[index], SEG->len);
 (gdb) list
 43          int index, n, i;
 44
 45          segment_address(SEG, row, col, &n, &index);
 46          if ((i = segment_pagein(SEG, n)) < 0)
 47              return -1;
 48
 50
 51          return 1;
 52      }
 (gdb) bt full
 No symbol table info available.
         index = -476
         n = 2
         i = 0
 so buf[index] on line 49 of lib/segment/get.c is trying to look for
 buf[-476] and generally speaking negative array positions are not allowed.
 That row=-1 looks a bit suspicious...
 I can follow that back as far as r.los/pts_elim.c L94 where
 row_viewpt=149 but neighbor_1_y=150, so row_viewpt - neighbor_1_y = -1.
 "g.region res=25 -a" does not fix it.
 Hamish
 ps- more of the backtrace follows
 #2  0x0000000000403b3e in find_inclination (x=0, y=151, viewpt_elev=250,
     seg_in_p=0x7fff36385b80, row_viewpt=150, col_viewpt=1055, docurv=0,
     ellps_a=6.9531885513800646e-310) at pts_elim.c:300
         del_x = 0
         del_y = 151
         dist = 3775
         picked_pt_elev = 1.40129846e-45
 #3  0x000000000040361f in hidden_point_elimination (head=0xf185c0,
 viewpt_elev=250,
     seg_in_p=0x7fff36385b80, seg_out_p=0x7fff36385b40,
 seg_patt_p=0x7fff36385b00,
     quadrant=1, sign_on_y=1, sign_on_x=1, row_viewpt=150, col_viewpt=1055,
 patt_flag=0,
     docurv=0, ellps_a=6.9531885513800646e-310) at pts_elim.c:94
         CHECKED_PT = (struct point *) 0xf34df0
         BLOCKING_PT = (struct point *) 0xf5f780
         orientation_neighbor_1 = 1.5707963267948966
         orientation_neighbor_2 = 1.5641297588910283
         inclination_neighbor_1 = -0.0080127842385963374
         inclination_neighbor_2 = -0.0080487974672544659
         interpolated_inclination = 7.8202765736839203e-317
         correct_neighbor_inclination = -0.0080487974672544659
         correct_neighbor_orientation = 1.5640850181635739
         correct_neighbor_x = 1
         correct_neighbor_y = 149
         neighbor_1_y = 151
         neighbor_1_x = 0
         neighbor_2_x = 1
         neighbor_2_y = 150
         uu = 1
         vv = 0
         mask = 1072693248
 #4  0x0000000000403de7 in segment (segment_no=4, xmax=150, ymax=506,
 slope_1=0,
     slope_2=0.5, flip=1, sign_on_y=1, sign_on_x=1, viewpt_elev=250,
     row_viewpt=150, col_viewpt=1055, patt_flag=0, docurv=0,
     ellps_a=6.9531885513800646e-310) at segment.c:81
         lower_limit_y = 0
         upper_limit_y = 0
         less = 0
         x = 0
         y = -1
         x_actual = 0
         y_actual = 1
         x_flip = 0
         y_flip = 1
         head = (struct point *) 0xf185c0
         PRESENT_PT = (struct point *) 0xe8aa50
         quadrant = 1
 #5  0x0000000000402dc0 in main (argc=6, argv=0x7fff36385fd8) at main.c:328
         row_viewpt = 150
         col_viewpt = 1055
         nrows = 1263
         ncols = 1562
         a = 506
         b = 150
         row = 1263
         patt_flag = 0
         segment_no = 4
         flip = 1
         xmax = 150
         ymax = 506
         sign_on_y = 1
         sign_on_x = 1
         submatrix_rows = 316
         submatrix_cols = 391
         lenth_data_item = 4
         patt = 0
         in_fd = 7
         out_fd = 8
         patt_fd = 0
         old = 5
         new = 6
         slope_1 = 0
         slope_2 = 0.5
         max_vert_angle = 0
         color_factor = 6.9531885516330262e-310
         old_mapset = 0xdb3510 "PERMANENT"
         patt_mapset = 0x0
         value = (FCELL *) 0x7fff36385bc8
         search_mapset = 0x404148 ""
         current_mapset = 0x7f937cbb1920 "paolo"
 ...[cut]
Ticket URL: <https://trac.osgeo.org/grass/ticket/111#comment:33>
