[GRASS-dev] Issues of 6.5 build on WinXP
Jan Tošovský j.tosovsky at tiscali.cz
Sat Jan 2 13:20:02 EST 2010
Error messages are properly recorded in the Command Console (wxPython) now,
but Clear output button doesn't clear anything.
When error messages are mentioned, there are several I've just met:
The first one appears 'sometimes' when Kriging interpolation is selected via
menu.
The second one when search in Command Console was tested. I found the
reason. The 'Find module' combo has not selected a default value. If the
'description' item is chosen, no errors appear anymore. But 'keywords'
throws another error message.
These errors are cosmetic, but I am reporting them in hope it can be
beneficial for someone.
Regards,
Jan
========= 1 ===========
  File "C:\OSGeo4W\apps\grass\grass-6.5.svn\etc\wxpython\gui
_modules\menuform.py", line 840, in OnOK
cmd = self.OnApply(event)
_modules\menuform.py", line 846, in OnApply
cmd = self.createCmd()
_modules\menuform.py", line 939, in createCmd
return
self.notebookpanel.createCmd(ignoreErrors=ignoreErrors)
_modules\menuform.py", line 1654, in createCmd
message=unicode(err),
UnicodeEncodeError
'ascii' codec can't encode character u'\xe1' in position 21:
ordinal not in range(128)
=========== 1 =============
=========== 2 =============
_modules\goutput.py", line 566, in OnSearchModule
if self.__checkKey(text, data['keywords']):
AttributeError
'GMConsole' object has no attribute '_GMConsole__checkKey'
