[GRASS-dev] [GRASS GIS] #855: d.text: rotate needs to rotate the background box too
GRASS GIS trac at osgeo.org
Mon Jan 4 09:02:49 EST 2010
 Reporter:  hamish   |       Owner:  grass-dev at lists.osgeo.org
     Type:  defect   |      Status:  new
 Priority:  normal   |   Milestone:  6.4.0
Component:  Display  |     Version:  svn-releasebranch64
 Keywords:  d.text   |    Platform:  All
      Cpu:  All      |
 as pointed out by Rich Shepard on the users mailing list, d.vect fails to
 also rotate the background color-box along with the text.
 there is already rendering code in d.labels to do this, it just needs to
 be incorporated into the d.text code.
 Also, if you had set the background color to "none" it was still getting
 drawn but using the same color as the text. I've just fixed that in 6.5svn
 (r40214). Previously the test for drawing background was just if the
 bgcolor= option was used at all.
 Hamish
Ticket URL: <https://trac.osgeo.org/grass/ticket/855>
