[GRASS-dev] Re: [GRASS GIS] #580: WinGRASS:
$GISBASE/etc/gui/scripts/ require something like $(EXE) to run
trac at osgeo.org
Tue Jan 5 05:31:36 EST 2010
#580: WinGRASS: $GISBASE/etc/gui/scripts/ require something like $(EXE) to run
Reporter: hamish | Owner: grass-dev at lists.osgeo.org
Type: defect | Status: new
Priority: blocker | Milestone: 6.4.0
Component: wxGUI | Version: 6.4.0 RCs
Resolution: | Keywords: wingrass
Platform: MSWindows XP | Cpu: Unspecified
Comment (by hamish):
for 6.4.0 I suggest to just copy the two problematic wrapper scripts +.bat
(if applicable) into $GISBASE/scripts/ as part of the wingrass packaging
scripts, just to make it work*. we can worry about fixing the underlying
cause later on and ship a cleaner solution with 6.4.1**.
[*] assuming doing that does work ... probably needs to patch the menu xml
as well.
[**] why did the 6.4.1 milestone go away? there were several bugs targeted
for it.
Hamish
Ticket URL: <https://trac.osgeo.org/grass/ticket/580#comment:29>
