[GRASS-dev] Problem updating svn add onns
Jarosław Jasiewicz jarekj at amu.edu.pl
Tue Jan 5 09:43:11 EST 2010
Hamish pisze:
> Jarosław Jasiewicz wrote:
>> When I try update r.stream.basins directory for most of
>> files I receive message:
>> it is
>> svn: Item '/grass-addons/raster/r.stream.basins/global.h'
>> is out of date
>> svn: Zatwierdzenie nie powiodło się (szczegóły
>> poniżej): // this means: commit failed (details below)
>> svn: File or directory 'global.h' out of date. try
>> updating
>> svn: resource out of date; try updating
>> what could be the reason for?
> someone else made modifications to those files since you last committed.
>   https://trac.osgeo.org/grass/log/grass-addons/raster/r.stream.basins
> always run "svn up" before you start up again after a break.
>   https://trac.osgeo.org/grass/wiki/HowToSVN#Beforemakingchanges
> Hamish
> ps- also, please use informative commit comments whenever you check
> something in, they help a lot with review & maintenance.
thanks I did.
Jarek
