[GRASS-dev] 6.4.0 never-ending story
Michael Barton michael.barton at asu.edu
Tue Jan 5 10:36:47 EST 2010
On Jan 5, 2010, at 6:17 AM, grass-dev-request at lists.osgeo.org wrote:
>> I just wonder about bugs which are marked as blockers for some months.
> http://trac.osgeo.org/grass/query?status=new&status=assigned&status=reopened&group=type&priority=blocker&priority=critical&milestone=6.4.0&order=priority
>> If nobody is going to fixed them they cannot be marked as blockers.
>> Then reporter should find someone to fix them, at the end the rc-stage
>> takes one year...
A big blocker was fixed yesterday - v.delauany broken on Mac and Windows.
Another one - v.digit broken on Windows - seems about to be fixed.
> I see:
> A) winGRASS related:
> * 580 WinGRASS: $GISBASE/etc/gui/scripts/ require something like $(EXE) to run
>  -> status unclear to me
I'm not sure about this either. Basically, there is a problem running scripts from anything other than the scripts directory. But I hear from the list that this has been fixed in at least some cases. Need someone with Windows to test.
> * 759 r.patch non-functional in WinGRASS 6.4 svn on Vista
>  -> awaiting guru comment
This is due to security routines on *some* Vista systems. It affects more than r.patch and can be capricious, affecting some systems and not others. The workaround is simply to turn off a form of the highest level of security in Vista. Someone who knows Windows could simply add that to the man page for r.patch.
> * 809 v.db.addtable consistently fails in winGrass
>  -> apparently not reproducable?
This is caused by the scripting issues above IIRC. Several of the db modules are scripts. These had problems if they called another script. I don't know if this is or is not a problem. Need someone with Windows to test.
> * 843 v.digit broken on new WinGrass release
>  -> contains a suggestion
In process of being fixed (message today from Hamish)
> B) Misc
> * 72  PNG driver: boundary rendering is off by one pixel
IMHO not a blocker. This affects visual output but not analytical capabilities. Also only noticeable in special circumstances.
> * 384 wxGUI: vdigit crashes on a big map
>  -> who can confirm?
Should not be a blocker for 6.4 as the TclTk interface is still the official one at this level.
> * 461 v.to.db crashes on a shapefile connected with v.external
> -> still valid?
Don't know.
Maybe Colin, Helmut, or someone else with Window and an up-to-date Wingrass can quickly run a test to see if any/all are still valid problems. Maybe that can eliminate some.
> I personally vote for going ahead and publishing this week RC6
> and after 1-2 weeks (really) the final version. A lot of patches
> should go into 6.4.1 then which are already piling up.
> Markus
If this is the list, it seems to me that we are about ready to release.
Michael
