[GRASS-dev] Re: [GRASS GIS] #809: v.db.addtable consistently fails in winGrass
GRASS GIS trac at osgeo.org
Wed Jan 6 07:38:34 EST 2010
  Reporter:  JonBall          |       Owner:  grass-dev at lists.osgeo.org
      Type:  defect           |      Status:  new
  Priority:  critical         |   Milestone:  6.4.0
 Component:  Vector           |     Version:  svn-releasebranch64
Resolution:                   |    Keywords:  v.db.addtable, wingrass
  Platform:  MSWindows Vista  |         Cpu:  x86-64
Comment (by hamish):
 Replying to [comment:9 hamish]:
 > I'm guessing G_tokenize(buf, ' ') + the same approach taken
 > by the wxGUI for this some weeks ago and pull off db as tokens
 > 4 to (ntok-1) and then drv with the last of G_number_of_tokens()?
 > I suppose a similar thing could be done with strrchr() to chop
 > the drv off the string first, set strrchr() to '\0', then to
 > get db go back and read {{{ %[^\n] }}} to the end of the
 > remaining line?
 an advantage of the G_tokenize() approach is that we can check for a
 minimum number of tokens.
 > if a layer 1 exists* it uses the default mapset/VAR values from
 > db.connect,
 that should read "does not exist"
 Hamish
Ticket URL: <https://trac.osgeo.org/grass/ticket/809#comment:10>
