[GRASS-dev] Re: [GRASS GIS] #842: wx location wizard: spincontrol
busted for UTM zone
trac at osgeo.org
Thu Jan 7 05:30:39 EST 2010
#842: wx location wizard: spincontrol busted for UTM zone
Reporter: hamish | Owner: grass-dev at lists.osgeo.org
Type: defect | Status: new
Priority: major | Milestone: 6.4.0
Component: wxGUI | Version: svn-develbranch6
Resolution: | Keywords: location wizard, utm
Platform: Linux | Cpu: x86-64
Comment (by hamish):
Replying to [comment:12 cmbarton]:
> OK. I just attached a new patch for GRASS 6.4:
> location_wizard.patch2. It's like the first one, patched against
> the svn from the root of your source tree. Hopefully, this will
> do the trick.
no dice.
I can spin it, it loops past 60 and back to 1, but if I touch the up/down
controls at all or type in a number I get a pop up window that says
"Something is missing! You must enter a value for Projection Zone
(1-60)". If I don't touch it at all I can go past and create a location
for UTM zone 30.
after I press ok on the error popup, this appears in the terminal:
File "/usr/src/grass/svn/releasebranch_6_4/dist.x86_64-unknown-linux-
gnu/etc/wxpython/gui_modules/location_wizard.py", line 769, in
OnPageChange
if int(self.pval[num]) > 60 or int(self.pval[num]) < 1:
ValueError: invalid literal for int() with base 10: ''
If I put some debug messages directly before L769,
num = self.utmzoneNum
print "num=",num
print "self.utmzoneNum=",self.utmzoneNum
print "self.pval[num]=",self.pval[num]
I get this on the terminal after pressing ok to the error popup message:
num= 0
self.utmzoneNum= 0
self.pval[num]=
Hamish
Ticket URL: <https://trac.osgeo.org/grass/ticket/842#comment:13>
