[GRASS-dev] Re: [GRASS GIS] #809: v.db.addtable consistently fails
in winGrass
trac at osgeo.org
Thu Jan 7 07:14:31 EST 2010
#809: v.db.addtable consistently fails in winGrass
Reporter: JonBall | Owner: grass-dev at lists.osgeo.org
Type: defect | Status: new
Priority: critical | Milestone: 6.4.0
Component: Vector | Version: svn-releasebranch64
Resolution: | Keywords: v.db.addtable, wingrass
Platform: MSWindows Vista | Cpu: x86-64
Comment (by hamish):
stuff to audit, both for spaces in path names and for correct column
parsing when fs=':' and a path like "C:\Documents and Settings" is being
parsed.
lib/db/
dbmi_base/login.c: ret = sscanf(buf, "%[^ ] %[^ ] %[^ ] %[^ ]", dr,
db, usr, pwd);
dbmi_base/dbmscap.c: if (sscanf(buf, "%[^:]:%[^:]:%[^:\n]", name,
startup, comment) == 3)
dbmi_base/dbmscap.c: else if (sscanf(buf, "%[^:]:%[^:\n]", name,
startup) == 2)
lib/vector/
Vlib/field.c: ndef = sscanf(buf, "%s %s %s %s %s", fldstr, tab, col, db,
drv);
Hamish
Ticket URL: <https://trac.osgeo.org/grass/ticket/809#comment:11>
