[GRASS-dev] Re: [GRASS GIS] #809: v.db.addtable consistently fails in winGrass
GRASS GIS trac at osgeo.org
Fri Jan 8 03:42:03 EST 2010
  Reporter:  JonBall          |       Owner:  grass-dev at lists.osgeo.org
      Type:  defect           |      Status:  new
  Priority:  critical         |   Milestone:  6.4.0
 Component:  Vector           |     Version:  svn-releasebranch64
Resolution:                   |    Keywords:  v.db.addtable, wingrass
  Platform:  MSWindows Vista  |         Cpu:  x86-64
Comment (by mmetz):
 Replying to [comment:11 hamish]:
 > stuff to audit, both for spaces in path names and for correct column
 parsing when fs=':' and a path like "C:\Documents and Settings" is being
 parsed.
 I had a look at the vector lib routines for reading/writing database
 connections (dblinks in the vector libs).
 The database is written to dbln without parsing any variables in it; that
 makes it possible to copy entire locations or provide sample datasets with
 vectors and attribute tables. Any variables in the database info are
 parsed by Vect_get_dblink() which calls Vect_subst_var().
 v.db.addtable calls v.db.connect which calls Vect_get_dblink() -> any
 variables like $GISDBASE/$LOCATION_NAME/$MAPSET are already substituted.
 The only way I see to get the database used by an existing layer *without*
 parsing any variables is raw parsing of the dbln file. AFAICT, vector
 modules use default database connection settings when adding a new table,
 also when e.g. adding a table for layer 2 and there is already a table
 connected to layer 1. Therefore it would not be unusual behaviour if
 v.db.addtable also always uses the default database connections.
 Markus M
Ticket URL: <https://trac.osgeo.org/grass/ticket/809#comment:12>
