[GRASS-dev] [GRASS GIS] #858: Display command from the Output
window not working
trac at osgeo.org
Fri Jan 8 05:16:59 EST 2010
#858: Display command from the Output window not working
Reporter: clerici | Owner: grass-dev at lists.osgeo.org
Type: defect | Status: new
Priority: normal | Milestone: 6.4.0
Component: Tcl | Version: unspecified
Keywords: | Platform: Linux
Cpu: Unspecified |
I tried to run commands from the lower part of the Output window in gis.m
GUI. The command with results listed in the Output window (as g.list rast)
run well. I opened a Monitor with: d.mon x0 and Run button. The Monitor
was opened. Then I deleted the command d.mon x0 and I wrote the command to
display the raster map geology (spearfish): d.rast geology and Run
(background) button but nothing was displayed in the monitor (same result
with d.vect).
This with: GRASS6.3, GRASS6.4, GRASS6.5. With GRASS6.2 everything run
well.
A. Clerici
Ticket URL: <http://trac.osgeo.org/grass/ticket/858>
