[GRASS-dev] Re: [GRASS GIS] #384: wxGUI: vdigit crashes on a big map
trac at osgeo.org
Fri Jan 8 08:55:51 EST 2010
Reporter: msieczka | Owner: grass-dev at lists.osgeo.org
Type: defect | Status: new
Priority: critical | Milestone: 6.4.0
Component: wxGUI | Version: svn-develbranch6
Resolution: | Keywords: vdigit
Platform: Linux | Cpu: x86-64
Changes (by hamish):
* keywords: => vdigit
Comment:
is there a way to count number of vertices? that is masked in the v.info
-t output. So I'm not sure how it compares, but here I tried:
g.region rast=elevation.dem
r.to.vect in=elevation.dem out=elev_dem feature=area -s -v
v.info -t elev_dem
nodes=523820
points=0
lines=0
boundaries=523819
centroids=246961
areas=246961
islands=1
faces=0
kernels=0
primitives=770780
map3d=0
du -sh vector/elev_dem
50M
it was slow & used a huge amount of memory, but it didn't crash.
(g65, amd64, debian/lenny)
some wxVdigit notes:
- chosen map name box on left not wide enough
- digitize points and move vertex buttons remain depressed.
after clicking on extra tools menu, that button stays depressed as
well.
- memory from top: VIRT 1775m, RES 1.3g, SHR 28m python
- it is slow but functional when zoomed in.
when zoomed to full extent of map it pegs my local eth0, CPU (Xorg +
ssh) near 100% for 10 minutes (& counting) while it attempts to redraw.
(session tunneled over ssh to the machine down the hall with 8gig RAM)
Hamish
Ticket URL: <https://trac.osgeo.org/grass/ticket/384#comment:2>
