[GRASS-dev] Re: [GRASS GIS] #759: r.patch non-functional in WinGRASS 6.4 svn on Vista
GRASS GIS trac at osgeo.org
Fri Jan 8 18:51:01 EST 2010
  Reporter:  cmbarton         |       Owner:  grass-dev at lists.osgeo.org
      Type:  defect           |      Status:  new
  Priority:  critical         |   Milestone:  6.4.0
 Component:  Raster           |     Version:  6.4.0 RCs
Resolution:                   |    Keywords:  r.patch, wingrass
  Platform:  MSWindows Vista  |         Cpu:  Unspecified
Comment (by hellik):
 Replying to [comment:9 hamish]:
 > so if you copy/rename "r.patch.exe" to "r.fred.exe", does it then
 magically work on Vista?
 > if so, would a r.patch.bat wrapper script suffer the same fate?
 > How that would end up with a "Bad file number" error I have no idea.
 > (does that mean bad a FID? or stderr/stdout not existing, or..?)
 > Hamish
 WinGrass65 WinVista32
 r.patch.exe renamed to r.helli.exe and started from the msys-shell and the
 wx-gui-commandline:
 GRASS 6.5.svn (nc_spm_08):c:/Users/syringia > r.helli input=extr1,extr2
 output
 =testpatch2
  100%
 Erstelle Supportdateien für die Rasterkarte <testpatch2>.
 everything is working, the two rasters were patched. so it's really the
 name that causes the problems. what's about a batch-file, i don't know.
 i see also in the windows-file-explorer that both r.patch.exe and
 v.patch.exe are marked by WinVista with a win-symbol, so Vista really
 recognize only by the file-name that there could something
 important/dangerous for the system and activates the UAC.
 Helmut
Ticket URL: <https://trac.osgeo.org/grass/ticket/759#comment:11>
