[GRASS-dev] Re: [GRASS GIS] #759: r.patch non-functional in
WinGRASS 6.4 svn on Vista
trac at osgeo.org
Fri Jan 8 20:45:18 EST 2010
#759: r.patch non-functional in WinGRASS 6.4 svn on Vista
Reporter: cmbarton | Owner: grass-dev at lists.osgeo.org
Type: defect | Status: new
Priority: critical | Milestone: 6.4.0
Component: Raster | Version: 6.4.0 RCs
Resolution: | Keywords: r.patch, wingrass
Platform: MSWindows Vista | Cpu: Unspecified
Comment (by hellik):
Replying to [comment:13 glynn]:
> Replying to [comment:12 hamish]:
> > sigh. what a complete pile of poo.
> +1
+1
> For the record, I'll include a copy of the referenced MSDN article:
> [http://msdn.microsoft.com/en-us/library/aa905330.aspx]
> Someone who cares about Windows (my "caring about Windows" level just
dropped by a large margin after finding out about this) might want to look
into how to create a "manifest" and whether this actually solves the
problem.
> Also:
> 1. Is this caused (in whole or in part) by GRASS being installed
somewhere other than the "Program Files" directory? If it is, then I care
even less. If there are still problems with spaces in $GISBASE, we should
fix them, rather than expecting GRASS to be installed somewhere else.
in my case (i don't anything about the original report), i don't install
the WinGrass-installer, i'm building WinGrass in the osgeo4w-stack which
is installed in C:\OSGeo4W. this path is proposed by the osgeo4w-
installer.
> 2. Is this relevant:
> Note The "User Account Control: Detect application installations and
prompt for
> elevation" setting must be enabled for installer detection to detect
installation
> programs. This setting is enabled by default and can be configured
using the
> Security Policy Manager snap-in (secpol.msc) or with Group Policy
(gpedit.msc).
> I.e. if you disable that setting, does the problem go away?
> If it does, then "problem solved", IMNSHO.
i've disabled this option, but there is no difference, the problem
resists.
the actual WinGrass-Installer proposes to install WinGrass to c:\Grass. So
maybe, like mentionend in the ms-document that c:\Program Files is a
"safe" site, the WinGrass-Installer should be changed to install the
application into c:\Program Files\Grass to exclude this possible source of
problems? Maybe this should be tested before Grass64-release?
Helmut
Ticket URL: <http://trac.osgeo.org/grass/ticket/759#comment:15>
