[GRASS-dev] Re: [GRASS GIS] #809: v.db.addtable consistently fails
in winGrass
trac at osgeo.org
Sat Jan 9 00:14:36 EST 2010
#809: v.db.addtable consistently fails in winGrass
Reporter: JonBall | Owner: grass-dev at lists.osgeo.org
Type: defect | Status: new
Priority: critical | Milestone: 6.4.0
Component: Vector | Version: svn-releasebranch64
Resolution: | Keywords: v.db.addtable, wingrass
Platform: MSWindows Vista | Cpu: x86-64
Comment (by hamish):
Replying to [comment:18 mmetz]:
> Replying to [comment:16 hamish]:
> > I've just attached to this ticket a patch against 6.5 which
> > allows spaces in pathnames
> Tested, works fine.
committed in 6.5svn and trunk.
> One minor bug though: in the new v.db.addtable line 129
[g.findfile]
> does not work with a fully qualified name,
interestingly it pretty much works if you just chop off the @mapset
part because g.findfile searches the full mapset path as a module would.
Anyway, I've ripped this code out now in favor of using the VAR file's
default DB settings for the mapset. So you are able to now control it
instead of being locked to what the map was already using. Committed in
6.5svn and trunk.
> For grass7, I would suggest to use fs="|" as default
> (anything but whitespace) whenever dblinks are written or
> printed, e.g. Vect_write_dblinks() and v.db.connect -p
Done and done. I'm sure we'll hear about it if there are any problems, but
after some light testing it seems to work ok.
the only thing left to decide is when to backport this stuff to 6.4.
Hamish
Ticket URL: <https://trac.osgeo.org/grass/ticket/809#comment:19>
