[GRASS-dev] Re: [GRASS GIS] #809: v.db.addtable consistently fails in winGrass
GRASS GIS trac at osgeo.org
Sat Jan 9 04:55:58 EST 2010
  Reporter:  JonBall          |       Owner:  grass-dev at lists.osgeo.org
      Type:  defect           |      Status:  new
  Priority:  critical         |   Milestone:  6.4.0
 Component:  Vector           |     Version:  svn-releasebranch64
Resolution:                   |    Keywords:  v.db.addtable, wingrass
  Platform:  MSWindows Vista  |         Cpu:  x86-64
Comment (by hamish):
 Replying to [comment:20 hamish]:
 > stuff to audit:
   lib/db/dbmi_base/login.c
   dbmi_base/login.c:      ret = sscanf(buf, "%[^ ] %[^ ] %[^ ] %[^ ]", dr,
 db, usr, pwd);
 This one will fail if the database path or passwd has spaces in it.
 In grass 6 this file is ~/.grasslogin6. In grass 7 it is in
 ~/.grass7/dblogin.
  - What this means is that Postgre, MySQL, etc will currently fail on
 WinGrass unless the databases are installed in a dir without spaces in
 them- which you may not have easy control over. I don't use those, so have
 nothing to test with. Hopefully someone who does use a DB that runs a
 server can have a look at this.
 Because it is a different file for grass 7 we don't have to worry about
 transitioning. So I've gone ahead and converted that to use "|" as the sep
 already.
 GRASS 6 will have to worry about forward/backward compatibility, so needs
 the full G_tokenize() treatment like vector/MAP/dbln got.
   dbmi_base/dbmscap.c:    if (sscanf(buf, "%[^:]:%[^:]:%[^:\n]", name,
 startup, comment) == 3)
   dbmi_base/dbmscap.c:    else if (sscanf(buf, "%[^:]:%[^:\n]", name,
 startup) == 2)
 these two are in old commented out code from grass 5 & not of concern.
 Hamish
 ps - see also #629 "WinGRASS: spaces in pathnames"
Ticket URL: <https://trac.osgeo.org/grass/ticket/809#comment:21>
