[GRASS-dev] Apply for write access to the GRASS-Addons-SVN repositor
Otto Dassau
otto.dassau at gmx.de
Mon Jan 11 04:10:21 EST 2010
Dear GRASS developers,
I would like to apply for write access to the GRASS-Addons-SVN repository.
I was looking for a faster v.rast.stats implementation to calculate
univariate statistics based on vector polygons, because I need to do this for
large raster maps and the current v.rast.stats is just too slow.
In the GRASS-Addons-SVN repository I found r.univar.zonal [1] from Markus
Metz, so I adapted the script v.rast.stats to use r.univar.zonal. The result
v.rast.stats2 is a lot faster. See test with spearfish below:
# current v.rast.stats
time v.rast.stats -c -e vector=fields raster=elevation.10m col=elev
real 2m6.139s
user 2m1.616s
sys 0m4.464s
# v.rast.stats2 based on r.univar.zonal
time v.rast.stats_neu -c -e vector=fields raster=elevation.10m col=elev
real 0m3.249s
user 0m2.784s
sys 0m0.444s
[1] http://grass.osgeo.org/wiki/GRASS_AddOns#r.univar.zonal
I would be happy, if the script v.rast.stats2 and r.univar.zonal from Markus
Metz would finally, after an incubation phase, make it into the sources for
GRASS future versions.
thanks a lot
Otto
