[GRASS-dev] Re: [GRASS GIS] #809: v.db.addtable consistently fails
in winGrass
trac at osgeo.org
Mon Jan 11 05:19:44 EST 2010
#809: v.db.addtable consistently fails in winGrass
Reporter: JonBall | Owner: grass-dev at lists.osgeo.org
Type: defect | Status: new
Priority: critical | Milestone: 6.4.0
Component: Vector | Version: svn-releasebranch64
Resolution: | Keywords: v.db.addtable, wingrass
Platform: MSWindows Vista | Cpu: x86-64
Comment (by mmetz):
Replying to [comment:19 hamish]:
> Replying to [comment:18 mmetz]:
> > One minor bug though: in the new v.db.addtable line 129 [g.findfile]
> > does not work with a fully qualified name,
> interestingly it pretty much works if you just chop off the @mapset
> part because g.findfile searches the full mapset path as a module would.
The @mapset part is already chopped off previously, you can replace line
129
eval `g.findfile elem="vector/$GIS_OPT_MAP" file=dbln`
with
eval `g.findfile elem="vector/$MAP_NAME" file=dbln mapset="$MAPSET"`
in order to get identical behaviour for fully qualified map names and map
names without the @mapset part. Currently in relbr64 you get different
results depending on whether you use a fully qualified name or not.
> Anyway, I've ripped this code out now in favor of using the VAR file's
default DB settings for the mapset. So you are able to now control it
instead of being locked to what the map was already using. Committed in
6.5svn and trunk.
That's probably the best solution.
> the only thing left to decide is when to backport this stuff to 6.4.
You have already backported the Vect_read_dblinks() fix, I would opt to
backport v.db.addtable as well.
Markus M
Ticket URL: <https://trac.osgeo.org/grass/ticket/809#comment:23>
