[GRASS-dev] 6.4.0 blocker bugs
Hamish
hamish_b at yahoo.com
Mon Jan 11 21:55:39 EST 2010
an update on current 6.4.0 blockers:
https://trac.osgeo.org/grass/report/13
#843 v.digit broken on new WinGrass release
- apparently working in 6.5, awaits backport to 6.4
#580 WinGRASS: $GISBASE/etc/gui/scripts/ require something like $(EXE) to run
- apparently fixed in all branches, awaiting next wingrass
build for final testing
#72 PNG driver: boundary rendering is off by one pixel
- not a blocker
#759 r.patch non-functional in WinGRASS 6.4 svn on Vista
- not a blocker: no solution, but work-around added to
the wingrass release notes
#461 v.to.db crashes on a shapefile connected with v.external
- not a blocker: figuring out how to make it come back with
a fatal error instead of a segfault would be nice though.
#809 v.db.addtable consistently fails in winGrass
#384 wxGUI: vdigit crashes on a big map
- not a blocker: corner case/general resource issue
#842 wx location wizard: spincontrol busted for UTM zone
- fixed in 6.4, awaits merging into 6.5 and trunk
#860 wxGUI: About Copyright missing its middle
- Blocker: missing license info
#? r.proj: still dies on wingrass.
- needs verification
So AFAIK it is just #843 (v.digit backport) and #860 (wx About)
left before we are ready to do RC6.
regards,
Hamish
