[GRASS-dev] Re: [GRASS GIS] #862: winGRASS path detection fails in Japanese locale (¥ instead of \ is used for c:\ etc)
GRASS GIS trac at osgeo.org
Tue Jan 12 01:07:38 EST 2010
for c:\ etc)
  Reporter:  neteler       |       Owner:  grass-dev at lists.osgeo.org
      Type:  enhancement   |      Status:  new
  Priority:  normal        |   Milestone:  6.4.0
 Component:  default       |     Version:  svn-releasebranch64
Resolution:                |    Keywords:
  Platform:  MSWindows XP  |         Cpu:  All
Changes (by neteler):
  * priority:  blocker => normal
  * type:  defect => enhancement
Comment:
 OK, my bad. The point is that when starting GRASS in cmd.exe, the terminal
 does NOT become a GRASS shell (see prompt below). Not surprisingly nothing
 works.
 Changing into enhancement: grass64.bat should print into the terminal that
 it is GUI-only and not a GRASS shell and that for a GRASS shell the user
 should use a different menu entry. This would reduce the (potential)
 confusion...
 But I am not sure where this message (better worded) should go.
 Markus
Ticket URL: <http://trac.osgeo.org/grass/ticket/862#comment:1>
