[GRASS-dev] Re: [GRASS GIS] #461: v.to.db crashes on a shapefile
 connected with v.external
    trac at osgeo.org
    Tue Jan 12 03:35:50 EST 2010
#461: v.to.db crashes on a shapefile connected with v.external
  Reporter:  msieczka  |       Owner:  grass-dev at lists.osgeo.org
      Type:  defect    |      Status:  new
  Priority:  critical  |   Milestone:  6.4.0
 Component:  Vector    |     Version:  svn-develbranch6
Resolution:            |    Keywords:
  Platform:  Linux     |         Cpu:  x86-64
Comment (by mmetz):
 Replying to [comment:6 glynn]:
 > Replying to [comment:5 hamish]:
 > > We may not be able to add the requested functionality for the next
 release, but can we do anything about replacing the segfault with a
 G_fatal_error()?
 > The following is based upon the backtrace, and is completely untested:
  --- lib/db/dbmi_client/select.c        (revision 40258)
  +++ lib/db/dbmi_client/select.c        (working copy)
  @@ -134,6 +134,8 @@
       table = db_get_cursor_table(&cursor);
       column = db_get_table_column(table, 0);   /* first column */
  +    if (!column)
  +      G_fatal_error(_("Table has no columns"));
       value = db_get_column_value(column);
       type = db_get_column_sqltype(column);
      type = db_sqltype_to_Ctype(type);
 Going a bit further to the root of the problem: in this case const char
 *col passed to db_select_int() in lib/db/dbmi_client/select.c is a zero
 length string, you could do for 'col' the same test that's done for
 'where' and exit with an error.
 Even further down, the question is, what to do if OGR_L_GetFIDColumn()
 doesn't return FID name, to cite a comment from Vect_read_dblinks().
 Markus M
Ticket URL: <http://trac.osgeo.org/grass/ticket/461#comment:8>
