[GRASS-dev] Re: [GRASS GIS] #856: r.proj fails in WinGRASS-6.4.0SVN-r40049-1
GRASS GIS trac at osgeo.org
Tue Jan 12 18:02:43 EST 2010
  Reporter:  malicera         |       Owner:  grass-dev at lists.osgeo.org
      Type:  defect           |      Status:  new
  Priority:  normal           |   Milestone:  6.4.0
 Component:  Raster           |     Version:  svn-releasebranch64
Resolution:                   |    Keywords:  r.proj fails
  Platform:  MSWindows Vista  |         Cpu:  x86-32
Comment (by hellik):
 Replying to [comment:1 hamish]:
 > Hi,
 > I have just tried r.proj on WinGrass 6.4.0svn r40049 binary + XP.
 > I reprojected elevation.dem and elevation.10m into a lat/lon wgs84
 location from Spearfish at appropriate resolution (g.region -m). No
 problems.
 > can you provide more detail about your input map (rows,cols,etc) and
 source/target projections? can you get it to fail using one of the demo
 locations? (spearfish or NC)
 > > As it was already closed, could it be related to the
 > > PROJ's development?
 > No idea, but I'd guess that it is a second, unrelated problem to the
 previous bug.
 > Hamish
 i've tested r.proj (self-compiled WinGrass r40386) with a DEM from
 EPSG:31287 to EPSG:31286, everything works.
 Helmut
 btw a next WinGrass-Installer (r40386) should be available soon
Ticket URL: <https://trac.osgeo.org/grass/ticket/856#comment:2>
