[GRASS-dev] Re: [GRASS GIS] #867: WinGrass64-compiling: `libintl_printf' is an unrecognized format function type'
GRASS GIS trac at osgeo.org
Tue Jan 12 20:23:19 EST 2010
type'
  Reporter:  hellik           |       Owner:  grass-dev at lists.osgeo.org
      Type:  defect           |      Status:  new
  Priority:  minor            |   Milestone:  6.4.0
 Component:  Packaging        |     Version:  svn-releasebranch64
Resolution:                   |    Keywords:
  Platform:  MSWindows Vista  |         Cpu:  x86-32
Changes (by glynn):
  * priority:  normal => minor
Comment:
 Replying to [ticket:867 hellik]:
 > unfortunately I wasn't all the building time in front of my laptop and
 couldn't catch all the messages,
 That's why you should redirect output to a file, e.g.
 make &> build.log
 > but I've seen in a few-modules (raster and vector etc.; i.e. nviz,
 v.what, v.out.pov, v.support, v.transform, v.to.db ) following warnings:
 I count 77 distinct occurrences (each one will generate multiple warnings,
 one for each occurrence of `__attribute__((format(printf,...)))` in
 gisdefs.h or G3d.h.
 Downgrading to "minor", as these are only warnings.
 They could be silenced by re-defining __attribute__ to an empty macro (as
 we do if __GNUC__ isn't defined).
 We could eliminate the redirection to libintl_printf, as none of the
 translations are currently using the %1$ syntax (which the MSVCRT printf()
 doesn't support, hence the redirection). However, chances are we'll forget
 to re-instate it if we ever need it.
Ticket URL: <https://trac.osgeo.org/grass/ticket/867#comment:1>
