[GRASS-dev] Re: [GRASS GIS] #863: set_env/unset_env should release
memory
trac at osgeo.org
Wed Jan 13 01:53:36 EST 2010
#863: set_env/unset_env should release memory
Reporter: rblazek | Owner: grass-dev at lists.osgeo.org
Type: enhancement | Status: new
Priority: normal | Milestone: 6.5.0
Component: libgis | Version: svn-trunk
Resolution: | Keywords:
Platform: All | Cpu: Unspecified
Comment (by rblazek):
GRASS modules probably don't set variables repeatedly, but in GDAL, for
example, if working with GRASS rasters from more mapsets/locations
simultaneously, needs to reset mapset/location if masking is not disabled.
It is using G_set_window() which checks for MASK.
Is there any other reasonable way how to reset environment when reading
rasters from more mapsets/locations?
Ticket URL: <http://trac.osgeo.org/grass/ticket/863#comment:3>
