[GRASS-dev] Re: [GRASS GIS] #787: v.in.db: add v.in.ogr-like "-t" option
GRASS GIS trac at osgeo.org
Wed Jan 13 05:06:37 EST 2010
  Reporter:  grasslandtom  |       Owner:  grass-dev at lists.osgeo.org
      Type:  enhancement   |      Status:  closed
  Priority:  normal        |   Milestone:  6.4.0
 Component:  Vector        |     Version:  unspecified
Resolution:  invalid       |    Keywords:  v.in.db
  Platform:  Unspecified   |         Cpu:  Unspecified
Changes (by grasslandtom):
  * status:  new => closed
  * resolution:  => invalid
Comment:
 Oops! I see, I should have asked on the mailinglist before filing this.
 Nevertheless: what I meant was something like
 #import vector from table without copying the table:
 v.in.db -t sometable x=x_col y=y_col cat=id_col out=somevector
 # connect to original table
 v.db.connect somevector table=sometable key=id_col
 But this could be mimicked by
 db.select sometable sql='select x_col,y_col,id_col from sometable' |
 v.in.ascii -t cat=3 out=somevector
 Thus I set this to resolved as invalid.
 Thanks for the hint with the pipe! Sorry for being to quick asking here.
 Tom
Ticket URL: <https://trac.osgeo.org/grass/ticket/787#comment:2>
